TwinTurbo.NET: Nissan 300ZX forum - any advice for replacing PCV valves?
Subject any advice for replacing PCV valves?
Posted by robbyg on September 10, 2001 at 12:19 AM
  This message has been viewed 46 times.
Message I have all the right parts listed in the FAQ, an 11 inch bent-nose needle nose pliers, and the hacksaw blade (all recommened odd tools). I've looked at the left side PCV today, and it seems like it'll be a pain to get out. Should I cut the tube attached to the PCV valve in half, and then remove it? The FAQ says only to cut the one on the driver side. Stupid question, but I want to make sure I do this right.
Is this right:
Don't torque anything into the plenum more than 15lbs?
All I need is the one set of long bent nose pliers?
I'm looking for any tip/tricks/hints you guys have come up with on your own. I've searched Technical and didn't find much.
Thanks.
Rob
